Motorola Handscanner loosing connection to AS400 application
Willem de Groot
Hi All
I Updated the 5508 from 7.0.230 to 7.4.100 and made it a cluster.
Sinse the Update the handscanners loose the connection to the AS400 Application.
Where to start troubleshooting?
I did a debug client, I see the client is roaming but I can not say if there is a relation between roaming and loosing connection to the application.
Please help.
We have a customer with these scanners all over the US and it seems like their is an issue with using WPA2/AES but not WPA/TKIP. I would contact your Motorola support team as they should know about this being an issue.
-Scott
20 Replies 20
Willem de Groot
More Information:
Security Policy ist set to : [WPA + WPA2][Auth(PSK)]
the Scanners are Motorola MC9090 Handheld Scanners
Problem first accured after the upgrade.
Degwi2,
Did you ever resolve this problem?  We're experiencing a similar problem with Moto on the same code release.
Scott Fella
What do you mean made it a cluster? Did you upload the FUS image also? What model scanners?
Post the show WLAN
-Scott
Hi Scott,
No, FUS was not updated.
>show wlan 5
WLAN Identifier.................................. 5
Profile Name..................................... SSAG
Network Name (SSID).............................. SSAG
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 43
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 36000 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... sy-sker-ch-scd-wlc-001
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ daten-vlan-5-ssag
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
--More-- or (q)uit
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
--More-- or (q)uit
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
--More-- or (q)uit
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
--More-- or (q)uit
MSAP Services.................................. Disabled
Scott Fella
Have you looked at this doc?
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns779/C96-609146-00_config_best_practices_for_motorola_st.pdf
-Scott
Hi Scott
I've seen this link, can't see what Version of WLC is in use here and.. before the upgrade, the scanners where working well.
Try setting the encryption to WPA/TKIP as this has fixed issues with one of my peers customers. WPA2/AES had issues!
-Scott
Scott Fella
It's also best practice on your other SSID's to choose one or another and not have both enabled. WPA uses TKIP and WPA2 uses AES.
-Scott
Hi Scott
I created a seperate SSID for testing now with WPA / TKIP only.
I'll let you know the result as soon I get feedback from the customer
-Scott
Willem,
Have you gotten any response back from the customer to see if changing it to wpa/tkip helped?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yahya Jaber
HI,
here is a guide for the handheld devices.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080ab7c01.shtml
WPA/TKIP is a good way to start.
I used to have a ticket in the past, with motorola, but that issue as i remember that the devices could not connect at all...we changed the WEP Key from 0 to 3
Scott Fella
My peer has an open ticket with Motorola on this issue. The customer has recently made the change a week ago and it's stable at the moment.
-Scott
hello Scott,
i would appreciate if you can share with me what did motorola do.
