12-15-2008 09:17 PM - edited 07-03-2021 04:54 PM
Hey,
We have around 40x 1200 access points and wish to implement MS PEAP with IAS as the radius server. We wish to have different VLAN's allocated based on group's within Active Directory. Is this possible? And no we dont have a controller.
If so, can someone point me in the right direction on how to set this up along with configuring the switches 2950/3550.
Mark
12-19-2008 07:24 AM
Here is the URL for the PEAP Under Unified Wireless Networks with Microsoft Internet Authentication Service (IAS)
Follow the guide it may help you
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
12-19-2008 12:16 PM
Hey,
Thanks for the reply.
I am trying to do this without a controller but would like to use the VLAN's from out switched network.
Is this possible? Cause I am not having any luck
Cheers,
MArk
07-11-2011 07:25 AM
Even I am trying to configure PEAP with Cisco 1200 and Microsoft IAS. Unfortunately all documents on the web point to the steps on how to do it on WLC controller. My only query is, will my Cisco 1250 AP support PEAP?
Were you able to configure PEAP on your AP's?
07-11-2011 08:56 AM
Please open up a new discussion for any questions that you have.. the post looks clean if we use different posts for every different question.. By the way to answer ur question here is the link..
Yes 1250 supports PEAP with IAS / ACS..
lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
07-12-2011 09:28 AM
I'm actually doing a proof-of-concept on this very thing right now. I am using 1242G's in standalone mode. I have two VLANs, one is our corporate Data VLAN (using RADIUS auth) and the other is a guest VLAN that's wide open. I'll try to post a sample config and I've found a couple of resources on the web that were quite helpful. Let me know what sort of issues you're having and I'll do what I can to help.
Mark
10-04-2011 05:32 AM
Were you able to complete the POC you mentioned in your post. If yes, then would it be possible to post the sample config you were talking about?
