multipe SSID
vishalpatil86
Level 7
Level 7
hi,
i have WLC and cisco APs
there is already one ssid broadcasting.
i want to broadcast two more SSIDs.
what are the settings?
Surendra BG
Nothing much.. Just configure the WLANs on the WLC and the make sure u check the broadcast option on the WLAN settings.. this will do it!!
Lemme know if this answered ur question!!
Surendra
Surendra BG
ok,
i have to divide this 3 parts of the building, lobby, room and hall
the person sitting in lobby must c the ssid configured for lobby only.
do i need to change vlan?
In this case you need to configure AP-Groups, so that the required WLANs on Required APs..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
lemme know if this answered ur question!!
Surendra
Surendra BG
