My Anyconnect Secure Mobility Client drops the connection suddently and is unable to re-connect until I restart my laptop
Hello all,
My company has deployed AnyConnect Secure Mobility Client 3.1.04059 and we use Windows 7
The client works fine most of the time, but all of a sudden the connection drops. I can see both the Windows Network and Sharing Center and Cisco AnyConnect suddenly disconnected. This happens most of the times that I change to another location with a different wi-fi network. With my past Windows 2003 and AnyConnect versions (not sure which one that was), the VPN connection would be recovered shortly after re-connecting to the new wi-fi, but with this version it will never allow me to connect to the new wi-fi. Sometimes, if I use the troubleshoot manager from Windows, it will reset my network adapter and that will allow me to connect to the new wi-fi network. Most of the times it won't.
In those cases, I need to close all programs, log off and log back into Windows. Some other times that will not work either and I will need to restart the whole machine. Restarting the Anyconnect related services alone does not help.
I am worried because today I lost the connection all of a sudden in my own home, while any other device could easily connect to the wifi. Anyconnect will simply say that it is unable to connect. After many tests I had to reset the computer.
Am I the only one seeing this problem? Any advice anyone can give me?
Thanks in advance,
Antonio
Hi Antonio,
Pls move this thread to below location. You may get responses from there.
https://supportforums.cisco.com/community/6001/vpn
Rasika
So it seems that I was barking at the wrong tree :)
After a bit more research on-line, I found that changing the Power management options for the Wireless network adapter resolved the problem.
I went to Control Panel> Device Manager> right-click on Wireless Network Adapter> Properties > Power Management tab > Uncheck 'Allow the computer to turn off this device to save power'
So far so good. Hope this helps others.
Best,
Antonio
