Hello
I am trying to connect an AP1100 in station workgroup-group bridge associate to another AP1100.
Without any authentication (authentication open) nad with static wep128 is everything fine. When I try to use leap then the AP1100 in wgb modus failed to authenticate with the message: %DOT11-2-UPLINK_FAILED: Uplink to parent failed: Unsupported authentication type
I tried differents software version, but no luck.
Configuration:
AP1100 WGB with c1100-k9w7-tar.123-4.JA.tar:
dot11 ssid xxx
authentication client username xxx password xxxx
infrastructure-ssid
interface Dot11Radio0
encryption mode ciphers wep128
ssid xxx
station-role workgroup-bridge
The normale AP:
Note: Authentication for PCMCIA clients works without any problem!
aaa authentication login EAP_METHODS group RAD_EAP
aaa group server radius RAD_EAP
server 192.168.100.1 auth-port 1645 acct-port 1646
ssid xxx
authentication network-eap EAP_METHODS
infrastructure-ssid
any input is very, very welcome
Oliver
