Need help building ACL on public interface...
robert-knapp
I have a 2611XM connected directly to the internet with a small PC network on the other side of the router. I would like to put an ACL on the public interface to block viruses and hackers.
I am looking for a list of commonly blocked ports. Is there a best practice I can refer to? I'm not trying trying to completely lock the router down but rather limit the massive amount of garbage that hits my public interface. Thanks.
steve.hart
here is a pretty standard one to get you started...
edit as necessary.
