Need Help mesh
I have a few questions
1) how to config mesh network on standalone cisco ap using 5 ghz, just give me configs please
2) 802.11n feauter enabling command
thank you
Surendra BG
1>> Mesh network cannot be built using AUtonomous APs.. MESH is a different design..
The below link may help you
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
2>> 802.11N runs on top og G and A and it alone cant drive..
Please mkae sure you are using below configs
WPA 2 Personal or WPA2 Enterprise with AES as the Encryption + WMM Enabled + All MCS rates enabled.
Surendra
Surendra BG
or
Open auth + no encryption + WMM Enabled + All MCS rates enabled.
Surendra
Surendra BG
Amjad Abdullah
although mesh is not available with autonomous, you can use WGB if you want to bridge the communication with the wired side.
Rating useful replies is more useful than saying "Thank you"
