Need help to setup wireless network on Cisco 1801W
kaya-saman
kaya-saman
I am trying to setup my Cisco 1801W to be able  to conenct through wireless with it apart from the fact that whenever I  attempt a conenction from my notebook I am unable to authenticate or  even connect to the unsecured network at all???
My notebook is an Hp Compaq 2230s with 802.11abgn interface and currently running Ubuntu 9.04 linux as the main OS.
The 802.11 manager sees the WiFi network as either WEP or unsecured when I specifically set it up to use WPA.....
I  also attempted to connect to the unsecured network using my personal  notebook and work notebook which runs Windows 7 but no luck at all in  establishing a connection.
The version information is as follows:
Cisco IOS Software, C180X Software (C180X-ADVIPSERVICESK9-M), Version 12.4(6)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 16-May-06 12:12 by kellythw
ROM: System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
Cisco1801W uptime is 2 weeks, 9 hours, 10 minutes
System returned to ROM by reload at 02:13:58 EET Sun Oct 31 2010
System restarted at 02:14:41 EET Sun Oct 31 2010
System image file is "flash:c180x-advipservicesk9-mz.124-6.T2.bin"
kaya-saman
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1801W (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FCZ1020138P, with hardware revision 0000
9 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
2 802.11 Radios
31360K bytes of ATA CompactFlash (Read/Write)
The wireless configuration is as this:
ip dhcp pool dpool30
    import all
    network 172.16.0.64 255.255.255.192
    default-router 172.16.0.65
    dns-server 172.16.0.200
ip dhcp pool dpool40
    import all
    network 172.16.0.128 255.255.255.192
    default-router 172.16.0.129
bridge irb
interface Dot11Radio0
  no ip address
  no ip route-cache
  encryption vlan 30 mode ciphers tkip
  ssid Cisco
     vlan 30
     authentication open
     authentication key-management wpa
     wpa-psk hex 0 12345.....
  ssid Cisco-GHOST
     vlan 40
     authentication open
  speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
  antenna receive left
  antenna transmit right
  station-role root
  l2-filter bridge-group-acl
interface Dot11Radio0.30
  description Radio inter for Vlan 30
  encapsulation dot1Q 30
  no ip route-cache
  no snmp trap link-status
  bridge-group 30
  bridge-group 30 subscriber-loop-control
  bridge-group 30 block-unknown-source
  no bridge-group 30 source-learning
  no bridge-group 30 unicast-flooding
interface Dot11Radio0.40
  encapsulation dot1Q 40
  no ip route-cache
  bridge-group 40
  bridge-group 40 subscriber-loop-control
  bridge-group 40 block-unknown-source
  no bridge-group 40 source-learning
  no bridge-group 40 unicast-flooding
interface Dot11Radio1
  no ip address
  no ip route-cache
  ssid Cisco
     vlan 30
     authentication open
  ssid Cisco-GHOST
     vlan 40
     authentication open
  speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
  station-role root
interface Dot11Radio1.30
  no ip route-cache
  bridge-group 30
interface Dot11Radio1.40
  no ip route-cache
  bridge-group 40
interface Vlan30
  no ip address
  no ip route-cache
  bridge-group 30
interface Vlan40
  description OPEN-ACCESS VLAN
  no ip address
  rate-limit input 1000000 1500 2000 conform-action continue exceed-action drop
  no ip route-cache
  bridge-group 40
interface BVI30
  description Birdge between Vlan30 and Dot11Radio0.30 for wireless network
  ip address 172.16.0.65 255.255.255.192
  ip nat inside
  no ip virtual-reassembly
  no ip route-cache
  ip tcp adjust-mss 1460
interface BVI40
  ip address 172.16.0.129 255.255.255.192
  ip access-group OPEN-ACCESS in
  ip nat inside
  no ip route-cache
ip access-list extended OPEN-ACCESS
  permit udp 172.16.0.128 0.0.0.63 host 172.16.0.200 eq domain
  permit tcp 172.16.0.128 0.0.0.63 host 172.16.0.200 eq domain
  permit tcp 172.16.0.128 0.0.0.63 host 172.16.0.200 eq 8000
  permit tcp 172.16.0.128 0.0.0.63 host 172.16.0.200 eq www
  permit tcp 172.16.0.128 0.0.0.63 host 172.16.0.200 eq 123
  deny   ip 172.16.0.128 0.0.0.63 172.16.0.0 0.0.0.127
  deny   ip 172.16.0.128 0.0.0.63 172.16.0.192 0.0.0.63
  deny   ip 172.16.0.128 0.0.0.63 172.16.1.0 0.0.0.63
  permit ip 172.16.0.128 0.0.0.63 any
bridge 30 protocol ieee
bridge 30 route ip
bridge 40 protocol ieee
bridge 40 route ip
Both wireless VLANs are also in the VLAN DB:
  VLAN ISL Id: 30
     Media Type: Ethernet
     VLAN 802.10 Id: 100030
     State: Operational
     MTU: 1500
  VLAN ISL Id: 40
     VLAN 802.10 Id: 100040
     State: Operational
     MTU: 1500
Can anyone help me sort through this??
I  had a similar sort of configuration for the Cisco 877W and 857W which  worked pretty well even though they were using updated IOS images so I'm  not quite sure what's wrong here.
Many thanks and regards,
Kaya
Ok, I figured this one out:
this statement was missing from the radio config of the WPA encrypted ESSID
encryption vlan 30 key 1 transmit-key
For my senario this should be wpa if I recall correctly!! (Config isn't infront of me now and VPN is down but using ? will clear things up on newly configured unit)
In addition to that the reason for the OPEN-ACCESS network not dishing out IP addresses was because there was an error in the ACL!
  permit udp any any host 172.16.0.129 eq bootpc
  permit udp any any host 172.16.0.129 eq bootps
This will enable all broadcast messages coming in from 255.255.255.255 for which DHCP uses initially. Also the protocol (port) needs to be allowed and since DHCP is based around the now obsolete BOOTP protocol and uses the same port; the bootp client and bootp server ports have also been allowed!!
This has now established a fully functioning wireless network.
I hope this helps someone who may have run into similar problems.
Kaya
