NEED HELP WITH 1200 Series Setup...
cuetor_VCC
I need to setup a 1200 series ap in a very particular way, but am having difficulty.  Basically, I need it to act as a wireless router in a sense.  I need it to.
1. Grab an ethernet address via DHCP. 2. Share its IP with the wireless clients, either DHCP or NAT Pool. 3. Redirect all incoming users to a webpage, and finally they need to be able to surf the web normally after that initial page.
Anyone have any input...?
Surendra BG
ANS - The AP is a layer 2 device and the IP will be assigned for BVI interface. if you have configured the switchport on which this is connected to to specific VLAN.
ANS - You can configure the AP for leasing IP address but NATing cannot be done on this since its a LAYER 23 Device and you need a layer 3 or a Router to do this.
ANS - Hers is the lin kto perform the same.. Not sure if the redirection works on the Autononmous APs for WEB page..
http://www.cisco.com/en/US/docs/wireless/technology/ip-redirect/technical/reference/ipredir.html#wp36493
lemme know if this answered your question..
Surendra
Surendra BG
