Need help with BVI
decibel101
Community Member
When I start my router it's giving me an error message and was wondering if someone could help me out.
error reads as:
"Configuration of vLAN subinterfaces and main
interface within the same bridge group is not permitted
Please configure the bridge group on this interface first.
STP: Unable to get the port parameters.
Please configure the bridge group on this interface first.Authorized access only
Disconnect IMMEDIATELY if you are not an authorized user!
Username:
Password:
Stephen Rodriguez
your Dot11Radio 0 Interface is in bridge-group 1, and your Dot11Radior 0.1 interface is also in Bridge-group 1. If you are doing sub interfaces on the radio, each sub interface needs to be in it's own bridge group, and the interface does not.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen,
I hate to bring up an old post, but I'm having this problem to; however, I believe it's specifically talking about my vlan. I just want to make sure I understand. I have to interfaces on Bridge-Group 1. You are saying that I can create a Bridge-Group 2, and put the vlan interface on that?
First, I'm new to bridging, but I wanted to clarify that I have a 871W router, and I have the FE4 and vlan1 interface bridged. I called the bridge bridge-group. The internet actually works pretty good, except for that error message.
Previously, I tried the BVI, but that didn't work, but when I bridged them, it did.
Good info, thanks.
