I require louder ringtones for the cisco 7920, i have tried downloading the loud ringtones from the website but they are not loud enough for the environment they are to be usde. Can anyone please help?
Ensure you are using w/ 1.08 firmware. Also ensure you call the phone not just playback the ringtone. If phone is called will ring normal for first second or so then increase to loudest allowed volume per compliance regulations. Can also set to Outdoors profile where ring volume is turned up to the max.
Learn, share, save
