NEMA rated Dipole antenna
mh@hcl.com
Hi any one please suggest nema rated Dipole antenna's fits to 3802e model
Haydn Andrews
It really depends on the dipole you are installing and the mounting orientation you are using.
But here are some options
Oberon 1021-00 with the AIR-ANT2535SDW-R will work, they also have number of other enclosures - https://oberoninc.com/
Otherwise https://www.ventevinfra.com/ has a number of options and their sales team is really helpful just tell them the AP and antenna you want to use and they will advise of a NEMA enclosure.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Haydn Andrews
thanks
