Newly installed AP's not accepting the clients
Raj_82
We have installed 3 AP's recently, But the clients are not getting connected to new AP's even though if the client nearest to AP. the clients were connected to the furthest access point instead of the nearest their AP.
Out of  4AP's . All the clients are getting connected single AP's.
Can anyone help me to troubleshoot this issue.
@Raj_82 wrote:
2,2800 Series AP have inbuilt antenna?  or without antenna it will not work?
2800 comes in two models:  2800I or 2800E.
2800I, "I" stands for Internal (antenna), have built-in WiFi antennas.  2800E, "E" stands for External, does not have an antenna.  The 2800E are shipped with a black dust cap/cover to minimize debris from lodging into the antenna socket.
The output from the "sh ap summary" shows the APs installed are 2800E.
Compatible articulated dipole (aka rubber duck) antennas for the 2800E are the AIR-ANT2524D and come in three different colours:  Black, Gray or White.
IMPORTANT:  Compatible antennas for the 2800/3800 have an orange band around the base.
Cisco Aironet and Catalyst Antennas and Accessories Reference Guide
@Raj_82 wrote:
3, I am not too sure MC33 model is having 2.4 or 5 ghz. Do we need change the setting in WLC?
Again, let's not get ahead of ourselves.  Buy the antennas required for the APs (3 APs x 4 antennas each/per AP = 12 antennas), install four antennas per AP (and not less) and then see if it improve things.  Easiest and fastest way to determine if the antennas are working is the LED will turn from solid green to solid blue.
22 Replies 22
Leo Laohoo
@Raj_82 wrote:
AP Name                         Slots  AP Model              Ethernet MAC       Location              Country     IP Address       Clients  DSE Location
AP7070.8b0f.936c                2      AIR-CAP2702E-E-K9      70:70:8b:0f:93:6c  default location      FR          113.33.108.28    34       [0 ,0 ,0 ]
AP488B.0A0F.33BA                2      AIR-AP2802E-E-K9       48:8b:0a:0f:33:ba  default location      FR          113.33.108.176   0        [0 ,0 ,0 ]
AP488B.0A0F.32F0                2      AIR-AP2802E-E-K9       48:8b:0a:0f:32:f0  default location      FR          113.33.108.175   0        [0 ,0 ,0 ]
OfficeAP                        2      AIR-AP2802E-E-K9       48:8b:0a:0f:30:b0  default location      FR          113.33.108.100   0        [0 ,0 ,0 ]
What antenna is installed on the AIR-AP2802E-E-K9?
Update the wireless NIC of the wireless clients.
Hi Leo,
Thank you for your reply
Please find the attached Image for AP.  This Wireless infrastructure is specifically used for Zebra scanners. Can we debug any AP log from the controller before suggesting to client to upgrade the driver for the scanners. Client may ask us to provide us evidence.
What image?
Slow down.  Let's not get ahead of ourselves without making an effort to perform any basic troubleshooting:
AP's are having 4 vertical antenna's . The AP image attached.
Try again.  That photo is AP7070.8b0f.936c.
How do I know?  Because that AP in the photo is a 2700 and with a BLUE LED.  And the only AP2700 and with wireless clients is AP7070.8b0f.936c.
Give me the picture of the other three.
Wait a second ... I know what is going on here.
There is only ONE (1) AP2700 and the rest are 2800.  The Zebra handset, what is the exact model?  The wireless NIC of the Zebra handset is ONLY 2.4 Ghz, isn't it?
Post the complete output to the following command:
sh client summary
Number of Clients................................ 35
GLAN/
RLAN/
MAC Address AP Name Slot Status WLAN Auth Protocol Port Wired Tunnel Role
78:b8:d6:4d:d5:2e AP7070.8b0f.936c 0 Associated 1 Yes 802.11g 1 No No Local
78:b8:d6:a4:5b:f3 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
78:b8:d6:c5:d2:99 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:0d:5d:4c AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:51:29 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:51:3b AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:63:d0 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:63:db AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:73:63 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:46:74:48 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
Would you like to display more entries? (y/n) y
94:fb:29:47:99:a5 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:47:99:be AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:47:99:c5 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:52:a3:91 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:52:a3:99 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:52:a3:ac AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:22 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:2a AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:32 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:41 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:4d AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:5c AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:88 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f5:f4 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:13 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:40 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:5e AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:9e AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:b7 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:c6 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f6:cf AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f7:16 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:55:f7:2f AP7070.8b0f.936c 1 Associated 1 No 802.11a 1 No No Local
94:fb:29:5a:d9:0f AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
94:fb:29:cb:bb:41 AP7070.8b0f.936c 1 Associated 1 Yes 802.11a 1 No No Local
I want pictures of the 2800.  All of them.
If they have those "black" stubs, I have a big surprise for you:  They are NOT antennas.  They are dust cover/shipping covers.
Presently these photos only we are having. I will try to get the remaining three AP'S photo.
I guess new AP's not having  antenna's.
1,Antenna it be supplied with AP's or do we need purchase separately?   because these are all purchased recently.
Thank you Leo for helping to analyze the issue.
Really appreciate your kind support. I will request my client to buy the antenna for the AP"s . Hope that will resolve the issue. I will get back to you   incase of any further help required.
Thank you very much for your support.
Are four ap broadcast ssid?
Hi Leo , Please find the photo of other AP's
