No color representation on site maps Prime 3.2
tstrode01
I have set up site maps inside Prime 3.2.  However, I am not getting any color representation on the maps.  The APs have been in the proper locations on the floor maps.  Am I missing a step or a setting?
Haydn Andrews
Maps > Wireless Maps > Site Maps (New)
Click the User Preferences icon in the top right corner of the Sites page
The following settings will have a direct reflection on how they apply
Use Dynamic Heatmaps
Minimum Number of APs for Dynamic Heatmaps
Then when on the floor map:
Expand the Access Points panel and play with these settings if its still not showing:
Heatmap Opacity (%)
RSSI Cut off (dBm)
If using the old maps then its called AP Heatmaps is enabled, under the floor map left hand side.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
