Not able to create a WPA2 network with a Cisco Aironet 2700 series model
andreasoc
I flashed a single Cisco Aironet 2701 (Cisco AIR-CAP2701l-E-K9) with a Standalone/Autonomous image.
If I create an open WiFi I can connect to it and I get an IP-address. So far, so good. but if I try to set up a WPA2 network, my Windows Client always tells me that no connection is possible with this network. It does not even ask for a password, I get directly the error message. I followed this youtoube intruduction: https://www.youtube.com/watch?v=AwuWsGGofT4
Can someone tell me what could be the error?
Configure_Cisco_AP #Standalone_GUI #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configuring Cisco Router to Access Internet through ISP Home router: ...
Rich R
Have you updated to the latest Intel driver?
https://downloadcenter.intel.com/download/30434/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters
10 Replies 10
marce1000
    - What is the particular Windows version and wifi-adapter type ?
 M.
Are you able to share the show run from the CLI or a screenshot of exactly what you have configured.
Can you also share the error message from windows.
Also take a look at Rasika's blog it might help you configure it
https://mrncciew.com/2013/03/02/autonomous-ap-with-wpa-psk-security/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hello, thank you for your answers, here is the config of the ap (and I attached the Windows error message - sorry it's german):
Building configuration...
Current configuration : 2225 bytes
! Last configuration change at 17:23:53 UTC Sun Mar 7 1993
version 15.3
no service pad
service password-encryption
hostname CiscoAP1
logging rate-limit console 9
enable secret 5 $1$ht/i$3Z1o5MtzmV8jWc2hdCtvc1
no aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 ssid Test Cisco
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 06291D25495C581B040417
no ipv6 cef
username Cisco password 7 047802150C2E
bridge irb
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm
 ssid Test Cisco
 antenna gain 0
 stbc
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 speed  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss9 a3ss9
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface GigabitEthernet1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address 00d7.8f89.2244
 ip address 192.168.248.42 255.255.252.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip default-gateway 192.168.248.253
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community private1 RO
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
 M.
Oh sorry,
Windows 10 21H1 and 802.11ac
- What is the wifi adapter type, meaning brand and model
M.
it is a Lenovo T570 with a Network card "Intel(R) Dual Band Wireless-AC 8265".
Rich R
are you kidding me? XD
It works now.
The current driver was relatively up to date (updated last month). But with the new drive update it worked, I never thought that this is the fault.... I spent a lot of hours in this.... thank you very much XD
Rich R
Glad that worked - step 1 always update to the latest driver!
