10-11-2017 12:25 AM - edited 07-05-2021 07:44 AM
Whats the max. number of APs per FlexConnect Group in AireOS 8.5 on the WLC 5508?
It used to be 25 APs per FlexConnect Group in earlier code versions for the 5508 while the stronger hardware supported 100 APs.
Has this possibly changed, and where could I find the corresponding documentation.
Thanks for any feedback.
C.
Solved! Go to Solution.
10-11-2017 01:19 AM - edited 10-11-2017 01:20 AM
The number of FlexConnect groups and access point support depends on the platform that you are using. You can configure the following:
Even in version 8.5:
A FlexConnect group can have a maximum of 100 APs on Cisco 7510 WLC, and 25 APs on Cisco 5508 WLC.
Dont forget to rate helpful posts
10-11-2017 02:42 PM
Hello Sandeep
Thanks a lot for the quick and clarifying reply.
Now I finaly found the part in the 8.5 config guide where it says that 'A FlexConnect group can have a maximum of 100 APs on Cisco 7510 WLC, and 25 APs on Cisco 5508 WLC.'
I couldn't find it in the first place because it seem to be hidden in the section about FlexConnect AP upgrades instead of being in the main section for FlexConnect groups where it idealy should be as it is a major information. Isn't it?
Cheers, Christian
10-11-2017 10:26 PM
Yes I agree with you. Mainly it should be in the Flexconnect Group section. I am glad that we found it.
Dont forget to rate helpful posts also plz mark the question answerd it may help others.
