Okay, New Problem on my 1310-BR!
datencio1
I just reloaded my IOS to version to 12.4(21a)JA1.  Everything seems to be working except for this problem that I have when restarting/rebooting the system:
The system is not configured to boot automatically.  The
following command will finish loading the operating system
software:
boot
Now I'll type this in the CLI, but I need it to be able to boot automatically.  I can't seem to find any commands in the ? menus to set this.  Does anyone know how fix this.
Thanks in advance.
Daniel
I used this command in 1140(c1140-k9w8-mx.124-21a.JHA) and have no problem.
Where did you used the command?(after fully boot up or in the boot rom? This should be used in boot rom. What's the output after you type "set" in boot rom?
8 Replies 8
Surendra BG
Let me know if i am understandingthe issue correctly... if we issue the command "reload" from the CLI, this is reloading byt in the middle of the process its going to still and at that time we need to issue the command "boot".
Or
Did we upgrade the sofware from the lower version to 12.4(21a)JA1 and are we issueing Boot??
Surendra
Surendra BG
Hello again,
This happens whenever the unit gets power cycled.  If I unplug the power or if the power goes off.  So if I am not in the CLI there is no way for the system to restart itself.  I then will have to go into the CLI and type the "boot" command from the "bridge:" prompt.  So this is what it looks like:
Xmodem file system is available.
flashfs[0]: 147 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 5549568
flashfs[0]: Bytes available: 2191872
flashfs[0]: flashfs fsck took 18 seconds.
Base ethernet MAC Address: 00:23:5e:99:52:bc
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
software:
    boot
C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
Compiled Mon 13-Jun-05 15:39 by ssearch
bridge:
Please try upgrading the software, if we face the same issue, then its a RMA (Replacement).
Surendra
Surendra BG
I have upgraded the software to the highest possible version without having to purchase a contract.  Also, as far as RMA, the bridge is out of warranty.  Is there any other suggestions that you might have?
Daniel
You can use "set MANUAL_BOOT no", then boot to fix it.
Thank you for your reply, but is there a certain model that this code works on or does it work on all models.  Or do you have to be use a certain mode in order for it to work.  I'm asking because every time I enter the command it error's saying that the "MANUAL" portion is wrong.  If I enter a "?" after the command "set" all I get is the option "memory".  For some reason it doesn't like that command.  This is the model I have:   AIR-BR1310G-A-K9-R. Also, here is my config file:
Daniel
version 12.4
no service pad
service password-encryption
hostname Wellness_Bldg
enable secret 5 $1$kM0k$dBG5sMvzFbXklTlCcFfZv/
no aaa new-model
dot11 syslog
dot11 ssid Wellness_Bldg
   authentication open
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid Wellness_Bldg
 antenna transmit right-a
 antenna receive right-a
 antenna gain 21
 power local cck 20
 power local ofdm 10
 power client 20
 station-role install non-root
 bridge-group 1
 bridge-group 1 spanning-disabled
interface FastEthernet0
 no ip address
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address 10.1.254.101 255.255.0.0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community defaultCommunity RW
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
Thanks for you help, that seemed to get it working.
Daniel
