P-LTE-VZ modem antenna connection help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-14-2021 12:05 PM
I have a IR1101 with a P-LTE-VZ module coming. I need to get an OMNI type outdoor antenna, antenna cable, and lightning arrestor for this install. I cannot find documentation on the type of antenna connection that is on the module. I'm believe that it is a "N" type but don't know the polarity or the gender. Help with the antenna connection type would be great. I was looking at the Cisco antenna "ANT-4G-OMNI-OUT-N" for this install. Any recommendations for antenna and cable would be great as well.
Chuck
- Labels:
Wireless Network Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-14-2021 09:12 PM
All the information can be found here.
https://www.cisco.com/c/en/us/td/docs/routers/connectedgrid/antennas/installing/cg_antenna_install_guide/Outdoor_Omni_for_2G_3G_4G_Cellular.html.
You can also contact vendors like Tessco and ask then for their recommendations.
https://www.tessco.com
