P2P Blocking Drop on WLC will be ignored
ciscoprolin
Dear All,
we have enabled P2P Blocking Drop on our WLCs for the SSID xxx.
But the Clients still see each other and can ping each other.
Any idea ? Cisco Bug ?
Thorsten
2 Accepted Solutions
Rasika Nayanajith
Is this across multiple WLCs ? I think this feature works for clients on same WLC
Rasika
HI,
You can use  ACL on the dynamic interface.It might impact the performance****
check this post about ACL config:
https://supportforums.cisco.com/discussion/10826006/howto-block-p2p-traffic-clients-connected-same-ssid-different-wlc
Dont forget to rate helpful posts
Rasika Nayanajith
Rasika
Dear Rasika,
thanks. Yes we have 2 WLCs with both WLCs being active. When I first activated the feature it was not possible to see other clients. But in the meantime now that we are running version 8.2.131.0 this is again possible.
Is there a way to stop the clients from seeing each other if this feature doesn't work for multiple WLCs ?
Thanks a lot,
Thorsten
HI,
