PAK for PI
Hi All
What is the procedure to install the license after generating license using the below PAK and whether any restart is require after installing the license? Thanks for your support
Any prerequisite?
R-MGMT3X-N-K9
R-PI30-SW-K9
L-MGMT3X-AP-K9
L-MSE-PAK
L-WIPS-ELM-100AP
Sandeep Choudhary
As per my knowledge... License installation is a no-impact process. No reboot is necessary.
Dont forget to rate helpful posts
