Passthru authentication web page and SSL certificate
smattingly
Level 4
Level 4
I have two questions:
We had a passthru authentication page working on our controllers with version 4.1.95.0 and it is not working after the upgrade to 4.2. What changed between releases?
How do I generate a CSR for the web authentication page so I can get a verisign/entrust key loaded on the controller? Is it as simple as the process in document ID: 98599? Does the web authentication process use same ssl key as the controller management interface or is it a different key?
erikszewczyk
You want document 70584 for WLCs (98599 is for WCS):
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
You can use seperate keys for web admin and web auth (transfer download datatype webadmincert/webauthcert).
Erik
Scott Fella
Something happened during the upgrade. Recheck the configuration again.
-Scott
