PEAP and certificate.
andrea.meconi
Level 2
Level 2
Hello.
I'm using PEAP with Cisco Secure ACS and AD. GPO enables clients to validate server certificate.
How can I deny access to users who have not "Validate server certficate" checked?
Thanks.
Regards.
Andrea
tfraij
Hello Andrea,
for the validate server certificate , this can be configured on client side only.
there is no configuration on ACS to force that, and you have to configure some policy at your microsoft ( so users can't change this check box :-) )
otherwise you can use EAP-TLS that force using 2 certificates , once on client and one one server ( mutual authentication).
Best regards
Talal
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
5 Replies 5
tfraij
Hello Andrea,
Best regards
Talal
Many thanks for your help Talal.
I understand that this is not a PEAP issue!
I believe I need to apply a filter on ACS (using a mac-address checked).
Regards.
Andrea
Talal is spot on. If you have a small deployment you could consider mac filtering. However this does become a big management burrden if you have a lot of devices. As mentioned, you can create a policy whereby "locking" the supplicant so that end users can not change "vaildate certificate".
Good!
Some users make connections using Apple.
I'm going to evaluate filter.
Other ideas?
Regards.
Andrea
You can still vaildate certs with Apple as well. How many clients do you have?
