Persistent Interference Devices on Channel 0 without Timestamp
Gehrig_W
Level 6
Level 6
Hello Cisco WLAN experts,
I have several questions to You regarding the following output from a 3802-AP on a 5520-WLC running V8.10.183.0
show ap auto-rf 802.11-abgn ZOM-AP534
Why does the output contain "0" for Channel ?
Why is there no time stamp in "Last Update Time"
When I compare to the output of a 2702i-AP nearby, I can see meaningful channel info:
show ap auto-rf 802.11b ZOM-AP40
But also here, a time stamp is missing. Any idea why ?
I have noticed also that the Web-Gui is no longer showing this Persistent Interference Device info for the 3802-model under:
Wireless -> Access Points -> Radios -> 802.11b/g/n/ax
For the 2702i-AP I can see this information also in the Gui under this path
Is this a bug or a new feauture in this release ?
Kind regards
Wini
Rich R
The missing clean air info sounds like a bug.
Apart from suggesting you update to 8.10.185.0 not much that can be done with AireOS now.
- That menu lists the AP radios - not interferers.  Still working fine for me.  If you don't see your AP there have you maybe re-assigned the radio to 5GHz (FRA)?  Do you see that AP under Wireless -> Access Points -> Radios ->  Dual-Band Radios ?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Gehrig_W
Level 6
Level 6
Hello Rich, thank You for Your reply.
You are not correct with Your statement.
Wireless -> Access-Points -> Radios ->802.11b/g/n/ax is showing also Interferes:
Who knows why the timestamp for "Last Update Time" is missing for the Microwaven oven ?
Is it because the influence is still active ?
By the way, I would have expected this Monitoring-information to be better shown under
Monitor -> Access-Points -> Radios -> 802.11b/g/n/ax
Maybe something for the next Software-Release.
Kind regards
Wini
You are viewing the Detail for a single AP from the list.  I am referring to the list.  If your AP is missing from the list you may be looking at the wrong list?
When I look at a 3802 I see: "Could not retrieve persistent device information because there are no registered persistent devices." in red.
If you don't see anything there that might be because the CleanAir process has crashed so check the CleanAir Operational Status.
If it's not UP then you should probably update to 8.10.185.0 to get the fix for https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd21996 which leaves CleanAir down most of the time.
Very unlikely - at this point we're not going to see much other than fixes for critical security vulnerabilities in AireOS for the remaining lifetime.  Any enhancements - zero chance.  Enhancements will only be in IOS-XE for 9800.
Hello Rich,
thank You for this information.
I don't think that teh CLeanair Process has crashed on the shown 3802-AP.
It's output can be seen on the command-line
Back to the intial questions ple
By the way, on 9800-platform, the only thing changed is the Class Type.
It shows "MW Oven" instead of "Microwave Oven".
This is not a good improvement in my eyes by the way.
Kind regards
Wini
