PI 3.0 Feature and Tech Templates = Can not see all WLCs to deploy to all
ROB ADAMS
Prime = 3.0
2504 WLCs = 8.0.121
Attempting to apply 2 different feature and tech templates to 4*WLCs.
To deploy, TemplateXXX I do see WLC#1 and not WLC#2, WLC#3 and WLC#4
Another TemplateYYY  it is the complete opposite.
I cannot see WLC#1 and see WLC#2, WLC#3 and WLC#4.
Why is this the case?
Yes, you need to create & deploy an interface for the WLAN, then the WLAN itself. Optionally AP groups if you want to select which SSID to be served on which AP.
Ryo Kato
Sounds like the WLC does not have the requirement to deploy the template. For example you want to deploy a WLAN profile, but the interface is not present on the WLC.
Did you also snyc the settings from WLC, so the PI knows what's actually on the controllers?
Realized the Wlans in question are not created on the WLCs, therefore the WLC was not showing under deploy.
What I am looking for is to create a new WLAN on the WLC using a PI template. Can this be done?
