POE cable for 1310
herve.sauton
Community Member
I need a POE cable of 40 meters between the 1310 bridge and the power injector.I found this reference: AIR-CAB100DRG6-F.
It's OK for a 1310?
Rob Huffman
Hi Herve,
I think you are better off ordering up a custom length cable (RG6 Coax with F-Type connectors). Here is an example of someone who makes up custom cables;
http://www.lextec.com/lex_custom.html
Hope this helps!
Rob
5 Replies 5
Rob Huffman
Hi Herve,
Yes, that Dual-Coax cable assembly will be perfect for your needs. This cable is referred to as a side note in some of the 1310 docs so you should be good to go 🙂
Hope this helps!
Rob
Hi Rob,
The AIR-CAB100DRG6-F cable Length is 100 ft. (30m), do you know if it's possible to interconnect two cables to make 60m or if it's possible to manufacture its own cable?
Herv?
Rob Huffman
Hi Herve,
Hope this helps!
Rob
Hi Rob,
Thanks for you help.
Herv?
Hi Herve,
You are most welcome my friend 🙂 Best of luck with your deployment!
Take care,
Rob
