poor LTE upload performance
ino
Level 4
Level 4
hi all
i have a c1111-4plteea router
it has a really poor LTE upload performance
the router i have used till now has an average up 10-25Mbps down 5-45Mbps (depending on weather day time and so on)
the c1111 has
up 1-5Mbps down 30-85Mbps
on the download side its a great improvement but on the upload side its barely useable
can this be some bad setting?
interface Cellular0/2/0
ip address negotiated
ip nat outside
dialer in-band
dialer-group 1
pulse-time 1
9/26 - 9/27 where the upload is a bit better its the old router moved out of his old optimal position
patoberli
This could be cause because of old/bad software. Are you running a current release on the new router?
Is the modem firmware (not sure if this applies to your model too) also up to date?
