11-21-2018 11:02 PM - edited 07-05-2021 09:29 AM
As I understood, Prime by default expects that access point is mounted on ceiling.
I have patch antenna Air-ant2566 and need a way to inform Prime that it is mounted on the wall
Solved! Go to Solution.
11-21-2018 11:11 PM
I found the way: main beam of antenna is controlled shown on the picture Azimuth and Elevation values, AP high also should be adjusted.
Log in to Community
