Possible Spanning Tree Prot problem
westmanm
Level 2
Level 2
I've got a large network of about 40 BR350 radios and 10 BR340 radios. We have a couple of different SSIDs to logicly breakup the network, however they are in one subnet.
The problem that I am seeing is the ocational drop of IP conectivity over one of the links for periods of exactly thirty seconds. In my mind this is the STP going into a learning mode and not passing any data. The question is 1. Why? There are no changes happening to this network topoligy. 2. How do I prove that this is the problem? 3. How do I tell what is causing the radios to go into learning if that is the case?
All radios are running current firmware (12.02T1 for the BR350s and 8.80 for the BR340s)
Mike
westmanm
Level 2
Level 2
Is this thing on?
-Mike
sbilgi
Level 11
Level 11
Make sure that the speed and duplex setting on ethernet of Bridge match with the Switch/hub. Also make sure that the cable and adpaters are all fine. The spanning tree issue can cause because of all these. Check this out:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/aironet/bridge/ebridge.pdf
