Power Injector Compatibility
c.fuller
Level 4
Level 4
I am converting from Aironet 1231 APs to Cisco 1010 LWAPP APs in the near future. My question is will the power injectors that I am using with the 1231s (AIR-PWRINJ3) work with the Cisco 1010 APs? Voltage requirements appear to be the same according to the specs. However, I can't find anything on CCO that indicates whether this is possible. I need to determine whether I should order the new power injectors (AIR-PWRINJ-1000AF) for the 1010s or if I can reuse the ones I have now.
vblavet
Level 3
Level 3
AIR-PWRINJ3 is not supported by AP-1000 familly.
AP-1000 familly only support standard 802.3af inline power. AIR-PWRINJ3 only deliver Cisco Inline Power.
Sorry about that,
Vincent
