03-07-2008 07:05 AM - edited 07-03-2021 03:30 PM
I am installing the above AP's into a network and they are connected to 6509 switches using WS-X6148A-GE-45AF modules.
When the AP's are connected and the command show power inline is issued some of the AP's show up correctly as:
cisco AIR-LAP1242AG
but others show up as:
Ieee PD
these devices are having an issue connecting.
Has anyone else seen this?
All inline power is set to auto.
03-07-2008 10:05 AM
I don't know about anything specific to the 6500. Most of my devices are powered with 3560s, but I have seen the "ieee PD" message. Most of the time it is a cable problem. I would have a pin out check of your links. This link has a pretty good explaination the two methods of powering. Some devices need pins other than 12 36, though I am not sure which method Cisco used for the 1242. You could attach one directly to the switch with a patch cord to test.
http://www.bb-elec.com/tech_articles/Power_Over_Ethernet.asp
Randy
03-07-2008 10:50 AM
Thanks Randy. Actually the solution was simpler than that. We rebooted the switches and everything is working exactly as it should. Not sure what happened though.
