Prime Infrastructure 3.3 won't display MESH Link SNR
b.tyler
I have added my MESH AP's to the map and the MESH links appear on the map as 0 SNR.  I can run the link test Parent-> Child and vise-versa and SNR os good.  If I go to Monitor->Access Points-><AP Name>-> Link detail, everything is zeroed out.  I do have "Refresh from Network" enabled.  Am I missing a configuration parameter somewhere?
patoberli
Which software is running on your APs? There were some versions affected by an SNMP bug which reported 0 as signal strength.
The latest versions of 8.2, 8.3 and 8.5 should have fixed this issue.
