Prime Infrastructure Wireless client monitoring
Sean Grubb
I'll cut to it, I have been asked to look at previously associated clients at a site. And then look at what the clients have been up to while connected to public wifi. As I am not familiar with some of the features in Prime, I was hoping someone could give me any amount of direction as to doing this:
Some clients using open access public wifi after hours
need to try and monitor or see what they used it for
Thank you kindly
balaji.bandi
what version of prime, you can generate reports, look at the reports section.
also check - Monitor / Monitoring Tools / Clients and Users
This you can not provide any information using prime.
BB
Leo Laohoo
@Sean Grubb wrote:
Some clients using open access public wifi after hours need to try and monitor or see what they used it for
Is there a proxy server between the Internet and the wireless client?
