Problem after enable HTTP on MSE
arybczonek
Community Member
In WCS i enable HTTP on MSE - attachment mse1.png after that i can't disable this because i got an error - attachment mse3.png, how i can disable this.
6 Replies 6
johnd2310
Level 11
Level 11
Are you adding new MSE or was this working before?
John
**Please rate posts you find helpful**
Working before, i uncheck the checkbox with https -> then save. Now i can't use https option.
Run the command /etc/init.d/msed status on the MSE. Does it show "use https" as true.
John
Product name: Cisco Mobility Service Engine
Version: 6.0.120.0
Hw Version: V01
Hw Product Identifier: AIR-MSE-3310-K9
Hw Serial Number:
Use HTTP: true
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: 262143
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
when using http can you connect to the MSE and view the configuration. If you can, then enable both http and https  and save. Then run /etc/init.d/msed status and check that https is true. Then you can disable http and only use https. If this does not work then you might need to clear the iptables firewall.
Have you tried rebooting that device before?
John
I got 404 on http same on https: "Error 404 - Not Found.
No service matched or handled this request."
Ok i turn on the https but can't turn off the http, which was previously disabled
i get an error, see attachment
