Problem after formating flash wlc 2504
Lujohny18
Hi people! I had problems with updating the WLC image from 7.0 to 7.2, and made a BIG mistake... I had formatted the flash. So now i do not have RTOS installed on my WLC. The only thing i have is the bootloader 1.0.16. Of course i can not install the code file (*.aes). I think that i need a RTOS to install first? but where can i get one for this device??? Or may be i can install any of RTOS from openwrt (for example) just to enter a normal command line or web GUI, after what i could install (upgrade) the normal .aes image. Please give some sugestions, what to do. Thank you!
22 Replies 22
khorheesoo
Level 4
Level 4
Dear Ivan,
What is the RTOS software?
Is it the same as the WLC controller software?
Does the name appear as below?
AIR-CT2500-K9-7-3-112-0.aes
After RTOS they will ask for the RF file... what is that?
Did you also update an AP image? Did you use TFTP or FTP for this?
Sorry for the million question but having the same problem and very hard to get support from Cisco TAC.
The rtos image is an image from Cisco TAC. That image you posted is the WLC software image not the rtos. If you can't boot your WLC then you need to have the rtos image and the process on uploading it from TAC.
-Scott
Hi Scott.
Thanks for your response. I will try TAC again and see if I can gain access for the RTOS software. Is that all that I require? I have a copy of the WLC controller software in case you are wandering.
That is all that is required. TAC will be able to provide that and walk you through the process.
-Scott
Abhishek Abhishek
Hello Ivan,
As per your query i can suggest you the following-
CLI Upgrade Procedure.
Please go through the link
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
In this section, we are presented with the information to upgrade the WLC with use of the CLI on the controller.
Hope this will help
josedonato
hello experts
my problem is the same, erased flash memory and even CLI does not start, choose to manually update images but then asks me for a filename FP, hopefully help me soon.
WLCNG Boot Loader Version 1.0.16 (Built on Feb 28 2011 at 13:14:54 by cisco)
Board Revision 0.0 (SN: PXXXXXXXXXX, Type: AIR-CT2504-K9) (P)
Verifying boot loader integrity... OK.
OCTEON CN5230C-SCP pass 2.0, Core clock: 750 MHz, DDR clock: 330 MHz (660 Mhz data rate)
CPU Cores:  4
DRAM:  1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1, octeth2, octeth3
  ' - Active interface
  E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
- Model: 1GB CompactFlash Card Firm: CF BXX2J Ser#: CX4XXXXXXXXXXXXXXXXX
- Type: Hard Disk
- Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press now to access the Boot Menu...
Boot Loader Menu
1. Run primary image (Bad image type) - Active
2. Run backup image (Bad image type)
3. Change active boot image
4. Clear configuration
5. Format FLASH Drive
6. Manually update images
Enter selection: 6                         ////Mode Manually update images
Launching...
Launching images...
init started: BusyBox v1.6.0 (2009-02-03 04:56:32 EST) multi-call binary
Mount failed for selinuxfs on /selinux:  No such file or directory
starting pid 655, tty '': '/etc/init.d/rcS'
Use DHCP for ip configuration (Y/n)? y
Sending DHCP request . . .
DHCP client bound to address 1XX.XX.XX.74
Enter TFTP server IP address[(1XX.XX.X.1 )]: 1XX.XX.X.246
!!! WARNING updating using .aes or unapproved files will disable this unit !!!
Do you want to update RTOS (y/N)? y
Do you want to update Primary Or Secondary Image (P/s)? P
Enter filename for RTOS update: AIR-CT2500-K9-7-4-100-60.aes
RTOS update Done                                        ///// DONE load image
Enter filename for FP update:                                      ///what????????????????????????????
Error Transferring FP!
Do you want to update an AP image (y/N)? n
AP Images Not Updated
Done.  Restarting...
Restarting system.
Board Revision 0.0 (SN: PSJ163000TC, Type: AIR-CT2504-K9) (W)
CPU Cores:  4
DRAM:  1024 MB
Flash: 32 MB
CF Bus 0 (IDE): OK
IDE device 0:
- Type: Hard Disk
Loading primary image (Bad image type)
100%
119581428 bytes read
WARNING: Data loaded outside of the reserved load area, memory corruption may occur.       /////what????
WARNING: Please refer to the bootloader memory map documentation for more information.  ////what???
Launching...
Launching images...
You have another post out there for the same issue. I would just follow up with that one.
You need to RMA the WLC or else opened a TAC case.
-Scott
Umit AYDINLI
It's a simple. First connect to the console witch wlc. and
(Cisco Controller) >transfer download datatype code
(Cisco Controller) >transfer download mode tftp
(Cisco Controller) >transfer download serverip 10.77.244.196
(Cisco Controller) >transfer download path .
(Cisco Controller) >transfer download filename filename.aes
for the referance page http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
