Problem NCS 1.4 AVC problem - no data available
I have problems with the configuration of the AVC with NCS.
I've enabled the functionality AVC on WLC software version 7.5 HA with no problems.
I visualize correctly the statistics.
I enabled netflow exporter to the Cisco NCS.
The NCS does not display any data.
NCS Version 1.4
NCS license assurance
I followed this manual
http://www.cisco.com/en/US/docs/wireless/controller/technotes/7.5/AVC_dg7point5.pdf
Have you any suggestions?
Many thanks
rpargal
7 Replies 7
David Ritter
Level 10
Level 10
Humm,  Prime 2.0 requires seperate licensing for support of Netflow/AVC.  I don't know about NCS..
Here is a CiscoLive presentation on this topic, you will find some valuable infromation from it.
BRKNMS-1040: Managing AVC with Cisco Prime Infrastructure 2.0
Rasika
**** Pls rate all useful responses ****
Thanks Rasika,
the link it's very interesting.
I opened a Cisco TAC for investigate.
Likely problem is a corrupt  file Xml in the software cisco prime ncs, caused of  procedure  upgrade release from 1.2 to 1.4
I await  news from cisco TAC.
Many thanks.
rpargal
Roberto,
Yes, a tac case is the way to go on this. Infact am investigating this issue as well.
If you can just attch the screenshots from Administration>Data Sources >Device data sources
Detail dashboards >>Application
Also, change looging to Trace, Admin>Logging>Message: Trace>Save
Pull the logs after 15 minutes.
We are interested in,
ifm_da, da_daemon.0 and sam_daemon.0
Sahil
Sahil,
Cisco TAC has resolved the issue.
Certificate problem tomcat.
evidence log problem:
86150: loopback: Dec 23 2013 06:44:00.517 +0100: %IFM-3-WITH_ERROR: %[ch=com.cisco.ifm.sam][mid=202]: Thread Id : [260] : SAM_COLLECTION_ERROR: [RESTDynamicInvocationProxy:Exception:javax.ws.rs.WebApplicationException: org.apache.cxf.interceptor.Fault: Could not send Message
To clean this up, you will need to delete tomcat cert. So the sequence of commands you need to run on admin shell is this.
# ncs stop
# ncs key deletecacert tomcat
# ncs start
Now work fine.
Thanks to all.
rpargal
Thanks for update this with resolution..+5
Rasika
Great.. i think i know who worked your case, didnt know that was yours though..
Happy that we have a resolution now.
Cheers..
