Problem- SSID is ON and OFF in Cisco 892W-AGN
aakashojha
Hi team,
I have a strange error in Cisco CISCO892W-AGN-E-K9 that i bought for our clients a month back.
- the router doesn't display the SSID for a longer period. Its like on and off of the SSID, showing sometimes and sometimes blank for the same device (Laptop/ Mobile/ or other Wireless Devices) within the range.
The router is in my office, but sometimes my laptop is connected, and sometimes it does not connect, and it is same with my other friends laptop.
Is it a problem with the device, configuration or the IOS issues?
Please help.
Leo Laohoo
Connect to the built-in WAP and post the output to the following commands:
1.  sh version;
2.  dir; and
3.  sh log
#show version
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 21-Mar-12 01:40 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
     Console logging: level debugging, 45 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 45 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 48 message lines logged
        Logging Source-Interface:       VRF Name:
Configurations--
config below-
dot11 syslog
dot11 ssid NWEDC
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 1102161612020003162F2A
username nwedc privilege 15 secret 5 $1$.SrJ$u3EVvjrMbli/I6UODVJoW.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid NWEDC
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
Ummmmm ...
Sorry, I think I wasn't being clear.  Can you post the following output from the WAP?
1.  sh version;
2.  dir; and
3.  sh log
Oops i was out for a while, sh version , dir and shlog listed-
#show log
    Console logging: level debugging, 43 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
    Buffer logging:  level debugging, 43 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 46 message lines logged
#show version
IID uptime is 1 hour, 51 minutes
System restarted at 05:19:16 UTC Fri Jan 11 2013
System image file is "flash:c890-universalk9-mz.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 892 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FGL1636279A
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ISDN Basic Rate interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO892W-AGN-E-K9    FGL1636279A
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
#dir
Directory of flash:/
    1  -rw-    40863252   Mar 1 1984 00:01:00 +00:00  c890-universalk9-mz.151-4.M4.bin
    2  -rw-        3700   Sep 8 2012 23:00:32 +00:00  cpconfig-89xW.cfg
    3  -rw-     3000320   Sep 8 2012 23:00:46 +00:00  cpexpress.tar
    4  -rw-        1038   Sep 8 2012 23:00:52 +00:00  home.shtml
    5  -rw-      122880   Sep 8 2012 23:00:58 +00:00  home.tar
    6  -rw-     1697952   Sep 8 2012 23:01:44 +00:00  securedesktop-ios-3.1.1.45-k9.pkg
    7  -rw-      415956   Sep 8 2012 23:01:50 +00:00  sslclient-win-1.1.4.176.pkg
256610304 bytes total (210493440 bytes free)
