Problem to register an Ap Aironet 1200 to a WLC 5500 Series
frank2812
Hi a i have this version Ap "c1200-rcvk9w8-tar.124-21a.JA2" and a WLC 5500. When i connect the ap to the network i can ping from ap to wlc and the wlc to ap,  but the proccess of lwapp messages give errors on the Ap when the Ap try to download the image from wlc and could not join the wlc. why this could be? this is the info of the wireless lan controller.
6 Replies 6
Stephen Rodriguez
What version of code are you running on the WLC?  The 1200 isn't supported after 7.0
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_2.html#wp947842
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
where can i see the version that you ask on the gui of wlc without "show version" on cli?
On the WLC main screen shows the WLC code version.
-Scott
In the WLC, run the command "sh sysinfo" and this will tell you what version the WLC firmware is running on.
George Stefanick
Since Leo Steve and Scott answered .. So will I !
If your 1200 only has a b radio it won't connect regardless.
All we need is Surendra and we can have a party.
