10-03-2019 11:22 PM - edited 07-05-2021 11:05 AM
I have tried to configure HA with 2 x WLC 2504, after going through all step:
- Create same interfaces on 2nd WLC with different IPs
- Enabled HA SKU secondary unit on secondary WLC
- Set AP primary Backup Controller
- Set Primary Controller and Secondary Controller IP+Name on all AP's HA tab
- Add mobility group on both WLC (both status changed to UP)
- Reboot 2nd WLC
After unplug the primary controller, all APs joined the 2nd WLC sucessfully. But when i checked the wireless tab, all AP's IP was 0.0.0.0 and there was no SSID broadcasted.
So do i have to Create the same WLANs and WLAN Groups on secondary WLC then add APs to AP Groups manually?
Solved! Go to Solution.
10-04-2019 08:00 AM
10-04-2019 02:22 AM
Yes, if it is N+1, you have to configure secondary wlc similar to primary WLC configuration (with different ip addressing for interfaces)
Rasika
*** Pls rate all useful responses ****
10-04-2019 08:00 AM
