problem with 7925 phones
Jozef Staruch
HI all,
I would like to share with you following problems:
The problem we still have is that some 7925 phones get stuck with the display saying “Konfiguriere IP” sometimes, I believe it is related to the renewing of the IP with the DHCP server.
The only problem is that the phones sometimes lose their IP, so it’s only DHCP to look at. The phones are simple DHCP clients, the WLC is transparent for the DHCP.
here is config:
ip dhcp pool VOIP
   network 172.25.0.0 255.255.0.0
   default-router 172.25.0.1
   dns-server 172.24.1.101 172.24.1.100
   domain-name zamek.de
   option 150 ip 172.25.0.21 172.25.0.20
   lease 30
interface Vlan25
 description VOIP
 ip address 172.25.0.1 255.255.0.0
The phones also seem to recover after some time, so they don’t know that it happened. Unfortunately we don’t know which phone is when affected. We just changed the phones to b/g only and EAP-FAST but it seems that makes no difference.
Thank you for help:)
5 Replies 5
Amjad Abdullah
What is your WLC model and version?
Are you using or hreap access points?
What is your phones firmware version?
Does the problem affect all handsets? Or some?
Rating useful replies is more useful than saying "Thank you"
phones 7925 with frimware 1.4.2
We are using version ov WLC    Product Version.................................. 7.0.220.0,   series 5500
It seems that every phone can be affected.
Are you using HREAP or local mode APs?
Do you have session timeout configured under the voice SSID? If yes, what ist he period that is configured?
If I click on Hreap groups I do not see any
Under WLANs H-Reap local switching and H-reap local auth is not enabled
Session Timout is not enabled
  Thank you for help
7.0.220.0 should be fine, but recommend to go to 7.0.235.0.
There were some fixes in the 1.4(2) release for a phone side issue, but see you are running that already.
Suggest to use 1.4.3.4, which is the latest release.
What AP models are you using?
If using Cisco 11n AP & 5 GHz, then is best to use 1.4.3.4.
If it is occuring with multiple phones simultaneously, then would more than likely be an infrastructure issue not a local phone issue.
