Problem with regulatory Domain
fcorreia01
Hello guys !
I'm in trouble and I need your help.
I I have the model AP AIR-CAP3502I-A-K9 with the controller 2504 (7.6.130.0
I can not enable radio 5 Ghz these Aps.
I am attaching a picture:
PETER MOOREY
In order to use 5Ghz with 3502 in Brazil you need to use AIR-CAP3502I-T-K9, not AIR-CAP3502I-A-K9.
If you check this table linked below you can find Brazil, and the column for 3502 AP, the correct regulatory domain is T:
http://www.cisco.com/c/en/us/products/collateral/wireless/access-points/product_data_sheet0900aecd80537b6a.html#Table280211abgnac
The 2.4Ghz works with A regulatory domain in Brazil, but not 5Ghz.  If you look at the (802.11)GN table it states that A is acceptable for 2.4Ghz only in Brazil:
http://www.cisco.com/c/en/us/products/collateral/wireless/access-points/product_data_sheet0900aecd80537b6a.html#Table480211gn
Hope this helps,
Pete.
