Problem with sending and receiving emails on wireless
diancious
I deployed wireless for one of my clients. All services and the internet are working fine.
Only problem is that while sending and receiving emails using Microsoft Outlook, there is a huge delay.
Even mails as small as 10-15 KB takes a lot of time to be sent out of the outbox.
During this time, I checked other services like internet, streamed a few youtube videos, etc but they were working perfectly fine.
There is no issue with Outlook because it is working fine in the wired network.
Thanks in advance.
6 Replies 6
Leo Laohoo
This doesn't sound like a wireless issue.  More like a configuration on the mail server.
What happens when you send/receive email using Outlook Web Access (OWA)?
Can you configure your Outlook to send/receive GMail/Yahoo account?
I tested the same by connecting to the wireless network of a different office location. I tried sending emails from there but there was no delay.
The mails were going and being received smoothly.
The backend mail server is the same.
That is the reason i was suspecting an issue with the wireless.
Can you please help.
gohussai
Level 4
Level 4
Actually if every thing is smooth other then outlook send/receive then possible only 2 options left.
Check the outlook with Gmail settting if it works perfect with Gmail then there is Mail server setting issue which you are using at the moment.
Note: Also clean your outlook temp files.
Let me know if it helps.
sobhardw
For any sort of outlook issues.Please check the below link :
https://support.microsoft.com/en-us/kb/936211/
Please let me know If the solution is useful.
sobhardw
For any sort of Outlook issues.
