problem with web access to WLC
adnanimarwane1
Community Member
Hi everyone,
I am working on 5508 cisco WLC, and I can not access WLC with SSH or GUI when I enable LAG,
when LAG is disabled, the GUI and SSH access works fine.
I am running the software version : 8.5.120.0.
thanks in advance
patoberli
Sounds like a misconfiguration on the switch side. You correctly configured the port-channel for the LAG function?
find below the configuration on the switch side :
interface Port-channel2
 switchport mode trunk
 spanning-tree portfast trunk
end
SW#
SW#sh run int Gi1/0/10
Building configuration...
Current configuration : 126 bytes
interface GigabitEthernet1/0/10
 description vers_WLC
end
SW#sh run int Gi1/0/12
Current configuration : 161 bytes
interface GigabitEthernet1/0/12
 channel-group 2 mode on
end
SW#sh run int Gi2/0/12
interface GigabitEthernet2/0/12
end
SW#sh run int Gi2/0/10
interface GigabitEthernet2/0/10
end
best regards
Configure them as indicated below:
Configuring Neighbor Devices to Support Link Aggregation
The controller’s neighbor devices must also be properly configured to support LAG.
  • Each neighbor port to which the controller is connected should be configured as follows:
    interface GigabitEthernet <interface id>
    	switchport
    	channel-group <id> mode on
    	no shutdown
  • The port channel on the neighbor switch should be configured as follows:
    interface port-channel <id>
    	switchport
    	switchport trunk allowed vlan <allowed vlans>
    	no shutdown
