Problem
guahaha658
Frequent Visitor
Frequent Visitor
Hello!
When attempting to change the DHCP server address for the Management VLAN on the WLAN controller, an issue or error occurs and the DHCP server address doesn't get saved. What should i do?
6 Replies 6
Mgmt VLAN of WMI use dhcp?
That seem not correct at all
MHM
at the management vlan i want to put the primary dhcp address
guahaha658
Frequent Visitor
Frequent Visitor
Please help me!!
guahaha658
Frequent Visitor
Frequent Visitor
This is what i have configured in WLC.
@guahaha658
Attach your PacketTracer file here, it is easier to help you. Zip it first. And explain what you are trying to accomplish and is not working
Rich R
Agreed with @MHM Cisco World - why are you trying to configure DHCP on your management interface?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
