Bookmark
Subscribe
2331
Problems connecting Android devices to Cisco ME
Athena1390
We have 3 AP1832i set to Cisco ME (1 acts as a call it a  "controller",).
They all have the latest firmware for APs (8.10.162.0).
Apple devices can connect without any problem, but no Android device can...
In order to find a solution, I tried to enable WPA3, but WLAN stay "Disabled" when WPA3 is choosed (along or without WPA2).
WPA3 does not work at all.
Do you have any idea to solve this issue ?
Thanks in advance for your help.
Thanks for the answer.
They list the SSIDs, but they cannot connect.
I found some information about the issue : Android is not able to connect using Fast Transfer, and best solution is WPA3.
However, WPA3 could not be Enabled using the GUI (AP always switch to Disable when selection WPA3).
Solution : configure it via CLI.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/wlan_security.html#config-wpa3-gui
Configuring WPA3 (CLI)
Procedure
Step 1
(Optional) Create a WLAN by entering this command:
config wlan create wlan-id wlan-name ssid
Step 2
Disable 802.1X support on the WLAN by entering this command:
config wlan security wpa akm 802.1x disable wlan-id
Step 3
Enable SAE AKM support on the WLAN by entering this command:
config wlan security wpa akm sae enable wlan-id
Step 4
Set the PMF to Required state to force clients to negotiate 802.11w PMF on the WLAN by entering this command:
config wlan security pmf required wlan-id
Step 5
Configure the PSK by entering this command:
config wlan security wpa akm psk set-key ascii psk-key wlan-id
Step 6
Disable WPA2 on the WLAN by entering this command:
config wlan security wpa wpa2 disable wlan-id
Step 7
Enable WPA3 on the WLAN by entering this command:
config wlan security wpa wpa3 enable wlan-id
Step 8
Disable 802.11r Fast Transition roaming support on the WLAN by entering this command:
config wlan security ft disable wlan-id
Step 9
Enable the WLAN by entering this command:
config wlan enable wlan-id
Works fine now !
What exactly do you mean with "but no Android device can..."?
  • Don't they list the SSID, do they try to connect but bring an error, do they connect but don't transmit data?
  • Is there anything in the Log?
Procedure
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Works fine now !
