Problems with new cisco AIR-LAP1131AG-E-K9, Green, Red, Orange Status LED
HI
Im having the same problem with two new cisco AIR-LAP1131AG-E-K9, when I connect them to my switch they come with a Green, Red, Orange blinking Status LED. The ethernet is Green and the radio is BLinking Orange
The problem is that this combination of Blinkin does not seems to part of the defined combinations on the  Cisco Aironet 1130AG Series Access Point Hardware Installation Guide
could anyone tell what does this means and how to solve it?
Thanks in advance
I have also done a donwgrade to c1130-k9w7-tar but still have the same problem
Scott Fella
Console into the AP and look at the output. That will tell you what's going on.
-Scott
Just Solved a miunte ago.
Just make the downgrade again and now i have my cisco working.
