Problems with Re-Direct on WLC
nehakulsum
Level 3
Level 3
Hi Experts,
I want to implement a guest login for the WLAN, but the redirect of Guest login webpage is failing. Could some one assist what needs to be configured.
Thanks in advance,.
Neha
Roman Rodichev
Level 11
Level 11
are you doing "url-redirect" from ACS by any chance? I've noticed before that it will not work if WLC is configured as "RADIUS (Cisco Airespace)" in ACS. Once I changed to "RADIUS (Cisco Aironet)", it started to work. Not a good fix, since "RADIUS (Cisco Airespace)" is required to support Airespace AAA parameters. 😞
Roman
manriquej
Visitor
Please make sure that you're web browser doesn't isn't set up to use a proxy server.
Also I remember one scenario where I got the web authentication (splash screen) working with Mozill firefox but I couldn't get it to work with Internet Explorer. I called Cisco TAC and they had me type in a command. The Web Auth splash screen did come up after this command was configured on the WLC. Unfortunately I can't remember the command. You can try giving Cisco TAC a call and see what you can find our.
Hope this helps,
Jorge
