QoS in WLC 2504 for Skype and Lync
LCMC
Hello everyone..
My costumers says that the quality of the videocalls are poor. What can i do for improve this.
i have little idea... please help me....
Luis Coiro
Rasika Nayanajith
Yes, enable QoS on wireless is much more than configuring a QoS profile on a WLAN. Please understand  these QoS design guidelines & implement them on your network.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch5_QoS.html
Once implemented you need to verify end-to-end QoS is preserve, so it involves QoS config/verification on your wired network as well.
You can refer some of my blog posts related to this topic. It will help you to get better understanding on what it involve configuring QoS
http://mrncciew.com/2012/11/28/understanding-wireless-qos-part-1/
Rasika
**** Pls rate all useful responses ***
5 Replies 5
Saurav Lodh
Level 7
Level 7
The controller supports four QoS levels:
  • Platinum/Voice—Ensures a high quality of service for voice over wireless.
  • Gold/Video—Supports high-quality video applications.
  • Silver/Best Effort—Supports normal bandwidth for clients. This is the default setting.
  • Bronze/Background—Provides the lowest bandwidth for guest services.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81831-qos-wlc-lap.html
To be clear those "levels" do nothing more than insure packets aren't over marked and have zero to do with marking up. Unless a non wmm client attaches ..
Check this read Microsoft about wireless
http://download.microsoft.com/download/B/5/7/B57FC5AD-6446-4AAB-905C-F24CEC214047/Delivering_Lync_2013_Real-Time%20Communications_over_Wi-Fi.doc
Thanks for this Link George, very useful +5
Rasika
Rasika Nayanajith
Rasika
