Question about AIR-BR1310G-A-K9-R
huwyhuwy123
Hi there,
Can anyone tell me if the AIR-BR1310G-A-K9-R  has an internal antenna?
I can't seem to find the answer to this anywhere!
Cheers,
Huw
HI,
The part number (the model number) of the device will dictate if the device comes with a internal antenna or if it needs an external antenns. For example, AIR-BR1310G-A-K9 is a 1310G bridge which comes with an integrated antenna. AIR-BR1310G-A-K9-R requires an external antenna.
You must buy external antenna for your AP.
Check more info here:
https://supportforums.cisco.com/document/10531/how-determine-ap-and-bridge-models-need-internal-antennas-and-those-need-external
Dont forget to rate helpful posts
5 Replies 5
Ashish Chandra
Yes it does.
The Cisco Aironet 1300 Series with integrated antenna can be quickly installed to provide a LAN bridge to a remote site or multiple sites. The 1300 Series with antenna connectors supports a variety of Cisco 2.4-GHz antennas, providing range and coverage versatility.
Source: http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet09186a00802252e1.html
thanks for replying.
I'm still not clear though on whether the AIR-BR1310G-A-K9-R contains an internal antenna or whether I will need to purchase an external one.
-H
HI,
Sandeep Choudhary
1300 Series Installation
The 1310 access point/bridge is available in two configurations:
  • Integrated antenna access point/bridge (with 13-dBi patch array antenna)
  • External antenna access point/bridge (with antenna connector for use with an external antenna)
huwyhuwy123
Thanks a lot!
Can you recommend an suitable (outside use) omni-direction antenna?
I was looking at the AIR-ANT2506. I presume there is just one antenna to buy per access point?
Thanks again,
H
