Question about Smart Antenna connector for APs 2802
aleopoldie
Level 3
Level 3
Hello experts,
I would like to use the smart antenna connector in order to have 1 2802 AP with 2 x 2544 antennas.
As I read, if I do that, I will not be able to use 5 GHz, is that correct ?
Did one of you use this smart connector ? What is your feedback ?
A.
Leo Laohoo
Disable 2.4 Ghz radio on the AP and test.
Make sure FRA isn't enabled.
I can't test is as I am planning to order this for a customer.
That's why I was opening this discussion, to know of someone already had a chance to test it.
A.
