Question on Firmware Release dates
Eric Kemsley
Why does 7.2 have a later release date than 7.3 and 7.4? This is for the WLC 2500 series. Do I install the firmware with the latest release date or the latest version?
http://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=280926587&release=7.2.115.1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Stephen Rodriguez
That version of 7.2 is a MR, not an intial release.
as for which version, all depends on what you are looking to do.  Read through the release notes and find which new features are things you need/want to do.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
George Stefanick
Hi Eric
Note that the difference between 7.2 and 7.3 is called a train .. In each train there can be multiple releases.
Typically there is significant difference supported in each train ..
